Are air charger a worthy mod? Pretty interested in the Simota Carbon Charger, but not sure if there is disadvantages doing the mod. Will ECU make the car feel back to stock after sometime?
Thanks
Thanks
Simota carbon charger is not air charger. If u are driving a auto car best is use a drop in. Otherwise is will be good to use a good japanese open pod. Go for a better filter.
Ecu will only limit the filter performance. U will still gain hp but not the max the filter give .
Project de creation
Specialize in Custom vinyl stickers. Hp: 91091901
Add: 50 First centre Serangoo north ave 4 #02-14.
http://www.streetdirectory.com/asia_...6304&l=10&s=sg
Projectdecreation@gmail.com
http://www.facebook.com/pages/Projec...46514455399360
www.projectdecreation.com
oh... man its confusing... so what is Simota Carbon Charger and how does it work? Information on the net is really confusing
Its a open pod with a casing. Most of the ppl call it a close pod.
EG of open pod.
Blitz Sus power LM open pod
http://www.blitz-performance.com/ind...=index&cPath=3
Blitz Sus power Stainless steel open pod filter
Blitz sonic power open pod
http://www.blitz-performance.com/ind...=index&cPath=2
HKS super power flow open pod
http://www.hksusa.com/products/?id=813
HKS super power flow reloaded
http://www.hksusa.com/products/?id=3190
EG of close pod
KNN Apollo kit come wit CAI piping and funnel
http://www.knfilters.com/universal/apollo.htm
EG of air charger
http://www.geocities.com/superaircharger/
Project de creation
good showcase of the different performance parts aka poison here bro.
Upz ur rep! :D
May you have enough happiness to make you sweet, enough trails to make you strong, enough sorrow to keep you humane and enough hope to keep you happy.
Project de creation
all affect low end?
If you want low end, go for drop in filter and stock airbox..
Or go for Blitz sonic power. Low end not so affect i think.
Project de creation
Anyone noe abt Simota Super spiral ? i need info on that on EX...
cos i used to install this on my vios...quite good...cheap reversible mod..
realli can feel the effect..
up to now still haben install cos i dunno wad's the size for the piping on lancer EX...the pipe to from airbox to throttlebody...plus there's many bends on that piping..dunno where or not to fix that spiral in sia...
can anyone help ?
I think they call it the Simota turbo ventilator or something right? I think some EX bros here fixed it. Just attach it in your ram pipe, just before the TB. If I'm not mistaken, u can check with bro Jernix but I think he dekitted it with his ADM air charger some time back. Cheers~
I still feel a good aftermarket drop in filter is still best!
Hehe K&N drop in!! Cheap and good. MAde in US of A. Can be use forever.
Project de creation
:D try Apollo kit 1st :D
GO TO GARAGE R for SERVICING !
The most Praiseworthy form of painting is the one that resembles what it imitates.~ Leonardo Da Vinci
Or u can Custom long stainless steel pipe ... from engine add air charger then another long piping then to apollo kit with out cai just at the fog lamp ... Steel pipe is therma wrap :D
Feel it :D try it on a brother car soild :D
Woah....u remember sia....kekeke. Sold my simota turbo ventilator liaoz....from how i perceive it...its not bad for pick up as when air travels in, the fan follows suit and rotates the fan to drive more air in at the beginning when u drive off. So picks up, based on theory, improves slightly. Some of my friends and colleagues who tried it, they realised that at constant driving....RPM actually is slightly lesser than normal. Which means that FC shld improve. Dunno why????
At present, i'm using ADM Air charger version2 (ADM Closed down liao but i think they are clearing stock). From theory, ADM V2 is an improved version cos now the hole is much bigger, thus travelling at higher cruising speed, it does not restrict so much air as per Version 1. And it is on b4 u step u step on the accelerator and spins even faster when u accelerate. Therefore, compared to using simota turbo ventilator, drives much more air to combust.
To conclude, I feel personnally that simota, due to the diameter of it, it actually restricts air at higher speed and RPM due to the size. I feel that it shld and will create air restriction rather than higher air flow on simota.
Please dun quote me as it is my personnal experience when i used both of it (Still using ADM) and my 2 cents worth of knowledge.
Bro, wad's ADM air charger ? how much the damage ? easy to install ?
u mean its not spiral but more than fan ? force air in ? or...
sound interesting :P But hor.....more air go in...meaning need more fuel to burn....meaning down in FC ? and more air go in...also got limit rite ? i mean depend on our airbox size... ? Sori for so many question...still learning :)
ADM is the brand i presume. U can google it and find out more. But the thing is the shop that made it has closed down. Basically, its like a much bigger fan and more powerful. Its not like simota that its self driven, but its runs on electricity. The moment u on your engine, it starts, and when u accelerate, it spins even more depending on how much u floor. When they tested it, the fan was like those kopi tiam huge industrial fan at full power. No joke. Very powerful fan.
oic....is that one legal ? i think i noe where got ...heard before...
thankz for sharing bro =)
Cheers
air charger is legal mod or not?
