Dear Sisters and Brothers Members,
Project Drum disc Conversion is currently now in Progress 20% more to go. For those who wish to convert from drum to disc u can do em :D I will post the picture really soon. ETA FEB 2010. Completed on 7 Jan 2010
Rear is Mod to EVOX RS Brake kit, OE Rotor Brembo
Front is really not so complex as the rear. so go to any professional workshop will help :D but must be 345 mm rotor :D
Question u may ask me :
1. Can use back handbrake cable?
2. Is Need to use other fabication brackets ?
3. upgradable to bigger rotor ?
4. Hydraulic handbrake needed ?
Heres the ANSWER. :
What u need is very simple just to change Knuckle and Hub !... well u need to using back stock EVOX items L and R Knuckle & hub Assembly. They are totally plug and play. This is SICK rite ?... The current evox rear is using a drum disc brake system. Which is very basically a drum but a disc over the drum. For more information can read on HowStuffworks... or Wike :D
Need to change Handbrake Cable ?...
Yup if u dun wanna also can need to mod the cable but i recommand that u change the cable Plug and Play.
Need to change ABS sensor Rear ?...
Is a no because is is the same as Evox wanna :D
Why we change evox Hub Assembly ?...
Mitsubishi parts comes wif replacement Hub Assembly. U can buy it at Cycle :D
This car is very unique. Only single cable to caliper. Other Honda etc they have handbrake cable and normal Hydralic Cable from brake pump. There is a handbrake cable that connect the hub.
Knuckle is also change. Due to Caliper Issue.
Next, u will not loose the handbrake function. U DON'T need to change to hydraulic unless u wanna to go on drift purposes. The Cost of the hydraulic from EAMVM a company quotes me in EURO 1000 plus for all necessary item needed to install on X or lancer. If u think that ur NA car need erm ... i dun think so ba. Even X don't use Hydraulic Handbrake.
After upgrading, Able to use stock OEM EVOX calipers as long as ur Rims are clear. or AP racing or Aftermarkets calipers for EVOX without headache liao ... :D
Damage for the EVOX Drum Disc conversion really depend on what caliper u are using.
But Knuckle and 2X hub are cheap. Can get from Cycle parts replacement centre.
If not u can PM me for Help and Diagram. I felt this is the best mod. And All non GT brother and sister are waiting for...
