Results 1 to 19 of 19
    Nov 2006
    A Little Red Dot
    5,534
    Default What other tyre profile can be used on Lancer EX?
    Complied a list of possible tyre profile useable on CY2 & CY4 as follows:
    Stock tyre specs (based on specs taken from Mitsubishi website):
    205/60/16 (Lancer EX 1.5 Elegance & Sport & Lancer EX 2.0 Elegance)
    215/45/18 (Lancer EX 2.0 GT)
    Possible tyre profiles (with least error margin):
    225/55/16
    245/50/16 - too wide?
    205/55/17
    225/50/17
    245/45/17 - too wide?
    195/50/18 - too thin?
    215/45/18
    245/40/18 - too wide?
    185/45/19 - too thin?
    215/40/19
    245/35/19 - too wide?
    - Even though the 2.0 GT uses a different stock tyre specs, the results are still the same as the rest of the models.
    - Calculated using the tire calculators found here.
    - Calculations are done without taking into consideration rim offset, wheel alignment and car height.
    - Main aim is to provide an idea of the most suitable tyre profile with min error margin relative to stock tyre specs.
    - Please do take note that different specs might have different effect to FC of your ride.
    - Handling characteristics of your ride might also be affected depending on the specs of the tires used.
    Nov 2008
    2,251
    actually it's also very much depends if the car is lowered or not, and offset of the rims does play some part too. I'm not too sure about other size, so contribute a bit on whatever I know. Correct me if I'm wrong.
    195/50/18 - Can fit the stock rims since stock rims only 18x7.5 but the stretch might not be enough and end up no side wall.
    215/45/18 - stock tyre size.
    225/40/18 - OK with or without lower
    235/40/18 - very likely need to roll rear fender to drop it safe.
    245/40/18 - can but need to do fender rolling.
    Nov 2006
    A Little Red Dot
    5,534
    actually i din really take into account the height. the impt point here is the correct size with min error margin. i assume the car is of stock height.
    Quote Originally Posted by Monsta View Post
    老大... my Ex 2.0GT c/w 215/45/R18 tyres
    if i want 2 upgrade let say 20"
    wats e correct tyre profile as 2 maintain accurate speedo reading?
    is it 235/30/R20 or 235/35/R20 ??
    thks :)
    "The winner is not always the fastest but...
    Always the one who slows down the least"
    http://www.youtube.com/watch?v=QRyqzYPyXW8
    James Tye Irene Ng
    235/30R20 would be right
    James Tye Irene Ng
    For 17" inch, what is the best setup?
    best setup i think 215/50/17.
    2nd will be 225/45/17
    anyone knows the offset for Ex 1.5? ( 205/60/16 )
    thx
    Quote Originally Posted by Horsie View Post
    thx
    Ya! I also want to know what's the offset? :)
    sorry...just wanna find out whether if offset +40 17" is suitable for 1.5A sports?
    Aug 2008
    3,205
    Currently running on 8.5" wide rims, 235/40/18. Percentage of error from stock is 0.8%. Offset +44.
    Hi All,
    I am currently running on stock tires and rims 205/60/16 Lancer EX 1.5 sports, would anyone be able to advice is the stock rims can accommodate the following tire size
    215/55/16
    225/55/16
    Thanks
    Quote Originally Posted by Rain View Post
    Saw a GT lower until 1 finger or less with 245/40/18........ did not do fender rolling at all....
    Quote Originally Posted by woomc View Post
    Maybe the owner did a wide body conversion. 245 very high chance will hit fender. Or he could have set to negative camber.
    Quote Originally Posted by WagonR+_=Minus View Post
    He did have set to negative camber...
    like mine, use 225/45/18 for Ex GT stock rims..is it ok??
    Quote Originally Posted by shairaziromainor View Post
    definitely ok if you're on stock suspension. Compared to using 225/40/R18 profile, you cannot lower the ride as much.
    hey guys, I'm planning on buying new mags and tyres for my Lancer EX. I don't want to go for 18", is there anyone here using 17" rims? Any recommendations are highly appreciated. Thanks!
  19. #19
    Using 225/R17/45, no problem
