Results 1 to 10 of 10
    Default Brake Rotor and Rim Sizes
    Hi bros, this is a guide for the maximum rotor size that can fit within a particular rim diameter.
    Stock Rotor size: 240 mm
    Stock Caliper type: 1-piston
    15" Rims
    Maximum Rotor Size: 286 mm
    Caliper Mounting: Direct fit
    Aftermarket Options
    • Evo 3/4 2-piston brake calipers with 260 mm rotors
    • Wilwood 2-piston Dynalite brake calipers with 280 mm rotors
    • Wilwood 2-piston Dynalite brake calipers with 280 mm rotors (2 pc)
    • Exzess 2-piston brake calipers with 282 mm rotors
    • VTTR mini 6-piston brake calipers with 286 mm rotors
    • D1 Spec mini 6-piston brake calipers with 286 mm rotors
    16" Rims
    Maximum Rotor Size: 303 mm
    Caliper Mounting: Mounting bracket required
    Aftermarket Options
    • VTTR mini 6-piston brake calipers with 303 mm rotors
    17" Rims
    Maximum Rotor Size: 330 mm
    Aftermarket Options
    • Wilwood 4-piston Superlite calipers with 330 mm rotors (2 pc)
    • Wilwood 6-piston Superlite calipers with 330 mm rotors (2 pc)
    I need to clarify the stock and Evo 3/4 rotor dimensions. Can any bros who know tell me the correct one? I just guess only.
    If got any mistakes, please let me know! I'm just sharing what I know. Also, if bros can update on caliper offset clearance, that'll help too!
    Lastly, let me know if I missed out any other brake kits!
    True driving starts at the limit of traction
    i think for 16inch can go up to 309mm rotor.. wilwood is 12.19inch which can fit 16inch rim..
    Stoptech big 4 pot should be with 330mm rotors need 17 inch to clear
    Quote Originally Posted by nigeln View Post
    15" Rims
    Maximum Rotor Size: 283 mm
    Aftermarket Options
    16" Rims
    Aftermarket Options
    17" Rims
    Aftermarket Options
    Bro,
    Nice piece of information on brake systems. It's a good info for newbie like me to seek upgrades. Now I can plan ahead and start looking for prices for each. :D THANK YOU!
    :yes:
    we study hard so that people don't look down on us, we study even harder so that we don't look down on people...
    *p.s I am returning whatever knowledge that is taken from here by posting it back. I am not guru, not pro but just another LMC supporter. :cheers2:
    Thumbs up! good info for newbie like me who know nuts about brake upgrades. with these options i can start doing little research. thx bro!
    p.s. this should be in sticky!
    I think stock evo 3 rotors are 276mm. Not sure if 4 are 2 pot, i always thought Evo 4 came with brembos liao.
    Jul 2007
    Bedok South
    3,467
    Good info bro.
    But do note, rim design plays an important part as well.
    Those rim design with spoke curve inwards, chances it that it might not clear the caliper. Best to either make some measurement before installation.
    i.e. the rim in the pix might have problem clearing the caliper as the spoke curves inwards
    http://www.advanti-wheel.com/global/...id=280&ptype=3
    comparing to this 1
    http://www.advanti-wheel.com/global/...id=294&ptype=6
    more straight. Easier & higher chance to clear larger rotor.
    But best best to measure before buying ; )
    セックス。ワイン。コーヒー。。
    Jan 2007
    UBI
    2,901
    15" Rims
    Aftermarket Options
    16" Rims
    Aftermarket Options
    17" Rims
    Aftermarket Options
    hmm....evo 3 rotor should be 276mm if i m not wrong... i have seen 17" with endless 6pot with 345mm rotor :)
    some 16" can clear 320mm rotor:
    FabulousX Pte Ltd
    51 Ubi Avenue 1 #01-21 Paya Ubi Industrial Park
    contact: 96677711, 68419329
    Opening hours: 10am-7pm Mon-Sat
    DBS/POSB/DINERS/UOB Credit cards Instalment plans available
    Sep 2009
    Central
    502
    thanks for the effort bro, this will be useful..
    do u know if we can mix and match evo3 calipers with other rotors of larger size?
    Sep 2009
    Bukit Batok Town
    2,758
    Nigel you may need to update this thread
