Page 6 of 6 FirstFirst ... 23456
Results 101 to 107 of 107
  1. #101
    Default
    Quote Originally Posted by DarkJudge View Post
    Eh... But u didn't explain what kind of vibration hahaha...
    Whole car vibrate, especially when startup
  2. #102
    Default
    I got exactly the same symptom with tancw, please update me if problem or solution found. Thanks. My ride ExGT CVT mileage 80K
    Quote Originally Posted by tancw View Post
    Vibration is when just cold start and stationary. No vibration after drive a short while. Even if off engine and start up again, no vibration at stationary since car already warm up and it is not cold start.
  3. #103
    Default
    Quote Originally Posted by DeroGT View Post
    check your engine mounts, perhaps time to change.
    we study hard so that people don't look down on us, we study even harder so that we don't look down on people...
    *p.s I am returning whatever knowledge that is taken from here by posting it back. I am not guru, not pro but just another LMC supporter. :cheers2:
  4. #104
    Default
    High chance engine mount. Mine like lorry until replaced rear right. Now damned silent
  5. #105
    Default
    Thanks for all advise! Problem solved! Culprit is the engine mount!
    For some years, I being hearing this sound when I hit the first hump on my first day of ride! Its also the engine mount!
    When engine is cool, vibration obvious cause the mount has not expand.
    2 of engine mount found torn!
    But changed the whole set include gearbox mount for LancerEX GT 08, mil 80K. <S$600 at SKM, Good Job, Good Service & explanation!
    <iframe width="480" height="360" src="http://s131.photobucket.com/user/Tonyzx11/embed/slideshow/GT%20Engine%20Mount"></iframe>
  6. #106
    Default
    Cheap. Your car should be as good as new now.
  7. #107
    Default
    Anyone can share where to change engine mounting?
    And roughly what is the cost?
    Driving ex 1.5
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
