Page 1 of 2 12 LastLast
Results 1 to 20 of 38
    Default CS3 MT Gear Box Oil
    Bros,
    Sorry to start a new thread on gear box oil but can't seem to find some information..
    1) What is the viscosity of the original gear box oil they use for our CS3 and what brand is it?
    2) How many litres of gear oil for MT CS3?
    3) What other brands and viscosity of oils that are recommended for MT CS3? For eg, Amsoil, Motul, Torco etc etc...
    Hope gurus can advise on this. Thanks in advance!
    went to dig out my car manual which have been missing since I got the car and finally found it lying somewhere in my house!! haha..
    Anyway here's the specs for the original Manual Transmission Oil :-
    Quantity: 2.1 Litres
    Recommended Lubricants:-
    Dia Queen New Multi Gear Oil
    API Classification GL-3, SAE 75W80
    or
    Gear oil API Classifcation GL-4,
    SAE 75W85 / 75W90
    Sep 2009
    Bukit Batok Town
    2,758
    changed to motul type 2 SAE 75W90, immidiaely shifting is so smooth.
    Quote Originally Posted by Gargoyle View Post
    That's what you did last nite when u hijacked my phone call? hahaha.. nice.!
    Sep 2009
    Bukit Batok Town
    2,758
    Quote Originally Posted by ftorres View Post
    Yes ! Haha
    I think i'll wait awhile more since my gb oil is used only for about 15k.
    Nov 2009
    West Side Rulez..
    840
    Default oil
    Garg, hw much is the gear oil for the motul u using? mind sharing which workshop u change? mine changing soon.. thanks.. :D
    sori to hijack....how many milage should we change?mine now almost 70 n i jus change once
    Quote Originally Posted by ansonpang View Post
    yours is manual transmission? 40k.
    Btw Garg did at Motec. Go PM him for the pricing and details ba.
    Nov 2009
    West Side Rulez..
    840
    ok bro torres.. pm garg liao
    yup manual...then 80 goin to change again....
    Aug 2010
    Bukit Panjang
    603
    i also pm garg liao, my gear hard to shift in when gear 3 to to gear 2 , gear 2 to 1
    Quote Originally Posted by koy86 View Post
    This is normal whichever gear oil u using ba.. hahaha..
    Aug 2010
    Bukit Panjang
    603
    u mean normal to hard to shift g2 to g1 and g3 to g2? , i drive a manual fd and avante b4 their gear are very smooth in shifting leh haha
    hahhahaa.. dun expect so much from CS3's gearbox. I suppose most of the bros here find it difficult to shift their gears also.. quite a common problem the last time i checked with the other bros.
    BTw, I just changed to Motul Gear Oil yday.. ^^"
    Aug 2008
    3,205
    Wrong car, but thought I might want to share some EX experiences as well. I also have problem shifting from G1 to G2, and sometimes (although VERY rarely) from G2 to G3. I also sometimes have problem engaging R, although that can be solved by simply releasing clutch pedal, then stepping on it again. I suspect it's the way the gearboxes are designed. Changing my MT trans fluid to a better one did help though. I encounter both problems even less frequently now (used to grind my G2 quite abit) and also smoother when shifting. =)
    Agree with Bro Razor. I think CS3 users are experiencing the same issues. Just that for me, I nvr really encountered problems shifting into "R" before.. 1 -> 2 feels hard and grindy.. and true.. a better MT gear oil helps..
  19. #19
    Aug 2010
    Bukit Panjang
    603
    where u change u oil at? can share with me the damage? haha
  20. Default
    Try adding MOS2 into gearbox oil. I have done it and find it good
    MT CS3 GLX FL stock with EVO 7 Full Aluminium Radiator/Bosch S5 75AH 650 CCA With Ultracapacitors, Bosch IR Fusion with Silicone Ignition Wiring/SARD Exhaust Wrapped /Stainless Steel drop-in Air Filter(fabric)/Ceratec added to 5w30 Mobil 1 oil & A/C compressor, MOS2 added to Gearbox MT oil & Power steering oil@ 6% /205/50/R16 Good Year Eagle F1, OD 612mm (Stock 195/60/R15 OD 615mm)/RON95 Caltex 690km/46.7L, RON98 Caltex 678km/46.9L, VPower 689km/46.3L
