Results 1 to 9 of 9
    Question High beam works, not right low beam
    Hi bros.. was wondering if anyone has any idea as to why my right low beam konked out but highbeam still works..
    was initially thinking of changing bulb till i realised highbeam ok..
    any help is greatly appreciated. Kum Sia!~!~!~
    cos a headlite bulb consist of 2 filaments inside... ur normal beam blew but nt the hi beam...
    nvrtheless... u stil need to chg the whole bulb haha... hope tis helps ^_^
    My Wifey: from EG9M >>> CS3M >>> FD1M >>> RD5A
    ~ 问世间车为何物 * 直叫我生死相许 ~
    Nov 2010
    West
    710
    Either u change the bulbs or all the way use high beam but not recommended... Joking...
    Change the bulbs bro...
    arn_mira
    The Chosen Few
    the bulb won't cost a bomb and won't cost as much as a HID bulb. just change to a new one lor
    Quote Originally Posted by Limes View Post
    Highbeam works means no faulty connectors.
    The solution is very fast & simple, get a set of new bulbs.
    Usually 1 side blow, the other side also about time.
    My experience is +/- 2 weeks side apart.
    Oct 2012
    Tampines
    329
    Mine just kanna today, NORMAL beam left side blew, but high beam still works.
    Any solution?.....
    -Truth Fears No Questions-
    gosh. my yesterday both light become very dim after changing my front windscreen. it's almost as good as no light. but highbeam is fine. is it the same issues too?
    Apr 2008
    Johor
    4,769
    Just change the bulb should be fine.
    Do not PM/Email/SMS me unless you really need to. If failure to comply all PM/Email/SMS will be auto ignored without notice.
    ** NEW ** -> Signature Policy | TCSS Policy
    Sep 2007
    Pek Kio
    85
    I just changed both the light bulbs for my headlamps yesterday to "Narva" light bulbs. I got my "Narva" light bulbs at $6.50 each. I changed both because my right was blown for low beam, might as well change both.
    I did it myself, just plug out the plugs behind the head lights, then remove the rubber seal and unclip the bulb. All done by hands. Just remember to use glove/tissue when installing the new bulbs so as to not contaminate the extremely sensitive bulbs! It is highly advisable not to touch the new light bulbs with bare hands.
    Anyway the "Narva" bulbs I bought was same as stock which is yellow. I don't install white lights as I hate to see white bright lights that blind me in the rear view mirror.
    Edit : I got the H4 Narva light bulbs at Kam Auto at
    65 Syed Alwi Road #01-01
    Mon - Fri : 9.30am to 6.00pm
    Sat : 9.30am to 6.00pm
    Sun : Closed
