Results 1 to 2 of 2
Thread: engine oil leak
    Default engine oil leak
    My engine oil is leaking from the drain nut, is where during engine oil change, the nut that use to drain off the exiting engine oil.
    any one know where to get a replacement of the nut? I'm looking for stock parts, not the magnetic type.
    Thanks guys
    Check with stockist Min Ghee. Workshops should be able to get for you too.
