Results 1 to 4 of 4
    Default Installing/ transferring of exhaust. Help pls :)
    Bought a Lancer Ex 1.5 today, wanted to install hks exhaust.
    If I buy from workshop (first hand) do I need to produce the car owner ic? Or the car owner must be there? (Ps: Car not under my name)
    If buy second hand exhaust, after I install and I go the the distributor do I need the car owner ic? The car owner must go down personally?
    After installing , go to sta need the car owner go down personally?
    For both situation, need car ownee nric. U can ask fhe shop(if buying first hand) if need the owner to be present or not. If 2nd hand, can ask garage r(where i transfer cert ownership).
    For inspection, definately need car owner nric. That also u have to check if owner needs to come down. Maybe write an authorisation letter?
    Mitsubishi Lancer GLX CS3 2011-2013
    Subaru Impreza TS 2013-2015
    Mitsubishi Lancer EX CY2A 2015-
    Jul 2010
    jurong
    1,369
    yup can write auth letter ...
    Life is like a dick, it get hard at times...:asshole:
    Thanks checked with the garage they don't need the owner nric
