Results 1 to 8 of 8
    IMM
    1,135
    Default Schnell engine oil 5W40
    Anyone use this before? Please review your feedback. Thank you.
    Top-up abit go for Shell Helix with PurePlus, very smooth. Giant Hypermart if got promo below $40.
    IMM
    1,135
    Ok, normally how much outside workshop charge to chg eo & oil filter?
    Apr 2009
    In your dreams
    1,462
    Quote Originally Posted by BergGLX View Post
    Speaking as someone from the automotive industry, i will never use this.
    You become the subject of ridicule when your own people have to emancipate for their entitlements, so, don't blame the online hostility, we just want our rights as lawful citizens of our own country.
    IMM
    1,135
    How about MM lubricant? Anyone tried?
    Apr 2009
    In your dreams
    1,462
    StickTo the approved sources.
    Engine is one of the most expensive component in your car, it's definitely wiser to refrain from using less recognised engine oil.
    Apr 2009
    In your dreams
    1,462
    Just a little bit of knowledge on the quality systems of the automotive industry.
    These is a Quality system widely practiced across the world known as ISO/TS16949:2009
    This quality system is only awarded to those in the OE supply network because of the higher requirements in the OE sector. Things like the APQP and all that are required in it are not demanded by the less stringent though universal ISO9001:2008 or 2015
    This means that ISO/TS16949:2009 awarded locations are sanctioned by vehicle makers giving them important specifications many shitty aftermarket brands don't have.
    CASTROL is managed by BP. This BP location has the ISO/TS16949:2009 certification
    http://www.bp.com/en_be/belgium/01_O...werpen_EN.html
    BREMBO is a member of the OE supply chain network with renown quality and engineering
    http://www.brembo.com/en/company/abo...-certification
    Bilstein is a member of the OE supply chain network with renown quality and engineering
    http://www.bilstein.de/en-uk/downloads/certificates/
    KYB Malaysia is a member of the OE supply chain network with renown quality and engineering
    http://www.kyb.com.my/about/quality-assurance/
    now... where is this schnell? BC? API? AHP Auto Solution? Maybe someone can enlighten?
