Results 1 to 13 of 13
Thread: Advice needed
    IMM
    1,136
    Default Advice needed
    Hi guys,
    When I step in the clutch there is a sound something like rusty sound. Could it be the pump or plates issue?
    Sometimes biting point is quit near, but mostly is normal biting point.
    Current millage is 97K 1st owner & on stock clutch.
    Thank you...
    IMM
    1,136
    To add on, I don't feel any slipping clutch so far..
    Anyone care to share or have similar experience.
    IMM
    1,136
    Please help... Thanks..
    IMM
    1,136
    No body experience this?
    Does the sound seems like from inside cabin or in engine bay?
    If inside, there is a pin at the clutch pedal stem, just put some grease (last longer) or spray some lubricant like WD40 at the pin area.
    IMM
    1,136
    Sound seem like from engine bay... but I can hear it in cabin..
    Does it happen when shifting from neutral to 1st gear, usually at morning when you first started the car? Does it sound like rubbing sound but rather low pitch kind, not the high screeching sound from auxiliary belts?
    Hi bro,
    Try to go workshop to confirm bcos might be clutch plate wore-out or loose belt.Safety come first bro take care..��
    IMM
    1,136
    Quote Originally Posted by Octopus View Post
    Every gear also got sound.. even car not moving if I press clutch got sound..
    IMM
    1,136
    Quote Originally Posted by Ariffin View Post
    Hi bro,
    Thanks bro... will send her for checkup.
    IMM
    1,136
    Update.. change whole set clutch plates & bearing.. no more sound...
    Congrats bro for problem solved.
    IMM
    1,136
    Thank you bro..
